Mikey R
Hi,
I was finally getting around to working with some hardwoods this afternoon - walnut and poplar, my two new favourites. For the walnut, I needed to do a small amount of resawing, 6mm thick at about 60mm depth, using my 26" Roberts and Lee 4.5 TPI rip saw.
In the past, Ive started the cut using a backsaw then switched to the rip saw after a few strokes. Now its time to grow up, and inspired by the recent dovetail threads, I tried starting the same way as I do with a crosscut saw, starting on the push stroke with only the weight of the blade pushing it down. Ive got the work piece held at 45 degrees so starting on a corner. This simply didnt work so well, the saw either jammed or jumped around and it took me a while to start the kerf where I wanted it.
Next weekend, Im going to need to do the same again, but on a number of boards. Does anyone have any tips for starting a saw with teeth this big?
