vapingvision
New member
Hello guys,
In the process of building a small utility room. I've got walnut in the main kitchen but can't afford for the utility room. Wickes have got some 3m beech tops in @ £90.
Is it possible to stain the beech to look similar to the walnut, I've read that Vandyke Crystals can be used to darken wood to the desired colour. I was then going to finish with 3-5 coats of finishing oil.
I used finishing oil on the walnut and I couldn't be happier with the finish / performance.
I've also read that I need to remove the finish that the manufactures would have put into the beech, before staining, would this mean sanding the beech right back, then applying stain, then apply finish?
Thank you in advance for any advice.
Best Regards
James
Best Regards
James
