Dickymint
I have applied my first coating's of sanding sealer.
All is well until I rub back it back (using a drill mounted sanding disc, clogs the grit very quickly though!) what happens is that streaks (of sealer?) appear.
On the first application I considered that I had been a little too liberal with the liquid however, application #2 was applied quite sparingly.
I have cut the first streaks back with 240 grit and the last coat back with 00 wire wool the streaks have now been removed.
Are the sreaks a result of poor technique?
Or to be expected?
Note:- #1 coat dried for 2 hours, #2 coat dried over night.
You advice would be most welcome,
Richard
Or to be expected?
Richard
