Hi everyone
I'm about to invest in some spraying equipment and I'd like to run my thoughts past some experienced (or not so experienced) sprayers!
I'm looking at 2 systems; (i) the Fuji Q3 HVLP turbine system which is £440, and (ii) the Sata MiniJet 4 HVLP gun and 7cfm Machine Mart air compressor - together around £330.
I've nevered used spray equipment before, but I just started making bedroom furniture which needs lacquer applying. The biggest thing which would need spraying is a 2m x 0.6m door (1.2 square metres each side).
The things I like about the Fuji system is that turbine systems are suppossed to result in more finish hitting the sprayed object, also the cup is 1 litre. What concerns me about the Fuji system is the gun getting warm and curing the lacquer.
The thing I'm not sure about with the Sata + compressor is the effiency of the finish hitting the object and also that the max cup size it will take is 0.3 litre. I reckon that will only be enough to give a coat to one of the doors without refilling. I can't use a larger capacity gun cos that'll mean a bigger compresor and I have got the room for one.
What does everyone else reckon?
Cheers, Andrew
Cheers, Andrew
