Holidaying in Palma, I couldn't help but notice the unusual door contraction for the large majority of the external doors.
If you carefully follow the mitre cut line you can see that it extends through the moulding on the rail and defines the width of the rail.
Back of the door. The iron bar is part of the fastening mechaniism. No beading to be seen to hold the panel in.
The rails and styles have been mounded and blend into the panels. The panels protrude for the rails and styles and are very difficult to see where they finish and tframe begins.
I can only surmise that unlike traditional English doors where the panels are either held in place by a grove or planted on mouldings that the rails and styles have a tongue and the panel is grooved. This appears to be a far superior method of panelled door construction in that the groove or rebate is eliminated in the rail and style which inevitably causes the panels to rot. In this method I would think that the water is shed and will lead to a longer life of the doors.
The mortise and tenons are unusual, I can't work out why they all seem to have the semi circle at the tip of the mitres.
Would welcome anyone's views if how these are actually made.
