Source of Metal 4" Ducting
AndyG
8 Feb 2005
North Yorkshire
Evening all,
I'm looking for some pointers in sourcing some metal 4" ducting and accessories.
At the North of England Woodwork Show last week I bought a new dust collector (at a bargain price) and am now looking to plumb it in to my various machines.
I know that Axminster do a very good range. But it's not really exhaustive. For example, I'm after the type of T-Junctions where the outlet is slightly skewed, halfway between a Y and a T. They do them in plastic but not in metal.
I'd rather go the metal route as grounding is easier, and to be honest, I rekcon it does look better ;-) (Why does form over function always creep in).
Anyway, has anyone found any good companies (preferably online) that sell such bits n bobs?
Many thanks
Andy
AndyG
8 Feb 2005
North Yorkshire
OLD, Freetochat,
Thanks for the links. Acutally CCL was the one other company that I'd spotted (Sorry, should have mentioned that). As far as I can see they don't sell blastgates. I can't find any guide to prices either. Probably best to drop them an email on Monday.
Andy
humanfish
17 Nov 2004
Farnham, Surrey
probably not much good for you being so far south but i used a company called Abbey Air Systems in Eastliegh which i would recommend to anyone. I found them on a thread on hear somewhere
http://www.abbeyairsystems.co.uk/index.html
I was able to get all the pieces i needed from them and they very helpfull
Alf
22 Oct 2003
Up the proverbial creek
Humph, I wish you guys wouldn't show off your plumbed-in systems like this. After re-attaching the hose to my dust-ex for the umpteenth time this morning (kept knocking it off with the timber I was planing #-o ) I'm just a teeny, weeny bit jealous... :mrgreen:
Cheers, Alf
woodshavings
20 Mar 2003
Alton, Hampshire
Cheers, Alf
Gosh Alf, I didn't notice the dust extractor port on my LV smoother .. :twisted:
OK, I'm going....
AndyG
8 Feb 2005
North Yorkshire
Never ceases to amaze me the number of responses you get on this forum!! Thanks all. OLD, thanks for the pointer to the blast gates.
I do have another question though. Wasn't sure whether to pollute the forum with another thread as it is related.
It comes down to whether an angled T junction is going to give much better air flow versus a standard T. The image below shows what I've got planned for distributing my dust collection.
I can get the standard Ts in metal (and everything else I need) from Axminster. Is it going to be worth the effort finding compatible angled Ts from elsewhere?
Freetochat
14 Feb 2005
Suffolk, UK
All the information recommends an angled 'T' as opposed to a 90 'T'. I changed my small bore system from 90 to 45 and the improved flow was noticable. I also get no hang ups on the T junction now, whereas before I used to. The only other thing I done with blast gates which may have improved the system was to install them to reduce pipe run lengths as much as possible, instead of being close to the machine connection.
Woodythepecker
30 Jul 2004
Andy, i wouldn't buy the ducting from Axminster. They want £3.20 for 0.5m or £6.37 per metre, yet the company (ccl) that old and Felderman recommended only want £3.50 for 1m.
Good luck with you system.
Regards
Woody
ProShop
19 Apr 2004
North Lincolnshire
Andy, I would avoid the T's if possible and use Y's if you can, the're much, much softer angled you can make them even softer by using 2 X 45% and a short length of pipe in between, Using the T's the air & dust are sandblasting the back of the main ducting before deciding which way they need to travel in the tube creating a fair bit of turbulance. The result will be a fair loss of suction imho.
looking at your drawing I'm not sure that putting the T's at an angle is going to acheive much IMHO, unless I'm missing something.
hope this helps, good luck :D
Scrit
17 Sep 2002
Andy
As FelderMan said Tees are a lot less efficient than Wyes, i.e. they cause a higher loss of SP (static pressure) = more air resistance and much more likely to plug. I'd always suggest looking at using 5in or even 6in ductwork if you possibly can as there is LESS "drag" inside a larger diameter pipe (calculate the circumference over the cross sectional area to see what I mean). If you want a good site on dust extraction, however, the absolute best is Bill Pentz's site - well researched and well informed unlike most (and should be made compulsory reading for woodworkers :shock: :lol: ). You don't have to build Bill's cyclone extractor, but there's plenty on there about ductwork (including friction coefficients) and system design, too, as well as a design for a home-made blast gate.
As you can't be too far from Bradford I'll suggest buying local and trying Adams Sheet Metal. Their quality is spot on, they make their own stuff (and might even show you their CNC plasma cutter running) and their prices are comparable, I feel. They do on-line ordering these days, too.
Scrit
