duncanh
At a demo at our club towards the end of last year the Sorby rep did some work with the spiralling tool. He said that he thought there was an formula to help you get an accurate spiral - what angle to use etc. This makes sense - some of settings shouldn't work for some diameters as the circumference of the piece needs to divide by exactly by the distance across the grooves. Has anyone come across such a formula? It'll save me the bother of working it out if it's been done before!
I've not used the spiralling tool much and I'd like to experiment more with it but other than coming across such a formula the only way is to get a bit of wood, turn it round, try a setting and if it doesn't work turn a bit off and try again. There really must be a better way which doesn't waste wood! Ideally I'd like to work on the side of large bowls (but I'm pretty sure the sides would have to be parallel to the lathe bed).
Any ideas?
Duncan
Any ideas?
Duncan
