Slim Parting Tool
THOMASB
4 Jun 2007
BRIGHTON
Just brought myself this tool, but have been told you need to re-shape it, is this correct? If so what angle is best? and how to do it!!!
:roll: :) Many Thanks Thomasb (John really)
I'm assuming you are referring to something similar to the top one in this pic. John.
Some people prefer to grind a small second bevel, I personally get on fine with mine 'as is'.
Hi (John really).
As with any cutting tool you really need a bevel to control the cut, especially if it is one you use single handed as when parting off. On these thin parting tools you normally have a 45deg bevel about 3 - 4mm long which is the one you use for control not the big bevel.
Used without a bevel they can be a bit vicious, and be hard to control, but some people prefer them that way. Personally I use the bevel.
Mine is an old saw blade and has no bevel. As said it can be viscious but I tend to only use it on smaller things so hasn't been a problem (so far).
I have the one same as the top picture on Chas post. I use it as it is in the picture. I didn't realise there was any other way.
Johnny B
Mornin' John.
If you decide to try the small bevel here is a example of the grind. You don't need a bevel of more than 3-4mm.
Now you can try both methods and decide for yourself.
