Hi,
I am looking to by a solid 10" sliding carriage table saw for regular hobby use. Some (e.g. Record TS205C, Jet JTP-600) seem to have the slider right next to the blade, others (Charnwood W629, W650, Axi AW10BSB2) have the slide 6-10" away from the blade. I appreciate the former are sometimes (not always) badged as panel saws but does anyone have a view on pros & cons of each type?
My use is likely to be mainly ripping hardwoods, some wavy edged, plus i'd like the ability to cross-cut up to 600mm accurately. 84 panels probably not on my likely cutting list.
Oh, and another question... The setting/assembly guides suggest setting the slide up to 1mm above the main table - presumably to ensure any timber clamped to the slider doesn't snag the main table. But isn't that going to make a mockery of the oft quoted desire for a flat table? Especially in the case of the saws with a slider right next to the blade,any planks being ripped are going to be high on the slider side, so therefore surely tilted over, meaning the cut will not be at 90 deg (or whatever your chosen angle is). Does anyone have this issue or am I missing something obvious?
Thanks again
Steve
Thanks again
Steve
