Hi. Am new to forums and hope I'm doing this correctly. Have just signed up with UKW as need some advice on replacing the NVR Switch on my SIP 01344 PT. I haven't had much success on the SIP website as there seems to be a lack of diagrams hence unsure of the part number.
Switched the machine on and it blew the 13Amp fuse in the plug. Replaced fuse, tried again, no luck. Checked replaced fuse which was still ok. Checked each of the three safety switches with meter and all were ok. Tried again with still no luck. Opened switch box and couldn't see or smell anything unusual. Stripped relay and reassembled but as said, all looked ok - no corrosion . Reassembled and tried again. It started. This is ok but I'm reluctant to believe all is well as something was not quite right.
Would like to line up the option of replacing the Switch if needed. Any advice?
Thanks.
Thanks.
