Jonesy
I wondered if anyone here has used the Sika Liquid batten system or similar flooring adhesive products for gluing solid timber flooring onto a concrete subfloor and whether they had any feed back on performance and longevity?
Following a rush of blood to the head I've bought 20m2 of solid oak plank flooring, the planks are 120mm wide and I'm searching for a suitable method for installing them over concrete. Battens are out because of the increase in thickness. Blinding nailing or screwing to plywood underlay is a possibility but the adhesive route seems easier, if it is likely to last - I'd like to get at least 10 years from the floor.
Does anyone have any advice on any measures necessary when installing wider planks? I've seen some articles suggesting that for planks wider than 100mm it is worth leaving a slight gap (<1mm) between the planks to allow for some expansion within the floor. I'd prefer to have the planks tightly locked but I don't want to risk having the floor buckle during seasonal moisture fluctuations.
Thanks,
Jonesy
Thanks,
Jonesy
