Peter G Denmark
I just figured out it's called "Gear Backlash" and the adjustment is called anti backlash, and is de facto in all high end table saws.
Tusses":8e69jjz7 said:you have found a way to tighten, and you only have to tighten once (twice)
nip them up nearly tight, then 'adjust' the top with a rubber mallet (carefully) . when you are happy, just tighten up fully.
You should only have to do this once.
In fact, mine was square when I bought it, after maneuvering out of one shop into mine. And it's still square now.
Peter G Denmark":37om0o6s said:Hey Sam.
Thank you for the feedback. I know stacked dados are illegal in the EU, and a lot of people frown upon the use.
Really, the shaft bore should be off-center in the bearing housing, and the hole in the sidewall of the housing for its capture should be a slot at constant Z, such that rotation of the housing by several degrees would raise or lower the worm gear to adjust the backlash...after which the pipscrew could be re-tightened and the tilt pointer re-positioned for accuracy. Faced with a concentric bore, your idea of milling the hole into a slot along Z to advance the worm gear toward tangency is good if the housing can be held securely thereafter; alternatively one may add shims to the thrust bearing stack between the worm and the bearing housing, at least up to the point where the pin for the handwheel starts to hang on the front of the bearing housing.Peter G Denmark":3gkymyjy said:it's just wierd that there isn't a way to adjust it in the saw. I mean - a bit of wear will occur over time, and most inexpensive contractor sa have an eccentric shaft that the worm gear is mounted to, so out can turn the shaft a little, and hence press the worm closer to the gear.
But on the Wadkin ags10, there is a fixed hooe that holds the shaft, and this is a serious design flaw, if there is no other way to adjust the mechanism.
Hmm - i hope i'm wrong, because the worm and gears doesn't look that worn, so if there is a way to push the worm closer to the center of the gears, or raise the worm a bit, the play would be gone.
Good luck with that. It's made of unobtanium, you know.Peter G Denmark":3gkymyjy said:If adjustment is impossible, where can i get a hold of the part they call "racked quadrant for rise and fall" part no.1026/14 for a wadkin bursgreen. The Number on the maschine is 10AGS7615428. That is the gear part - the worm looks pretty new.
