HappyPixie
Hello assembled geniuses! I'm sure one of you can get me out of a pickle. I bought a Woodcut bowl saver (http://www.axminster.co.uk/woodcut-bowlsaver-bowl-coring-system) on evil bay with the intention of cutting the centres out of big blanks that I intend to mount outboard of the ML8. Imagine my surprise when the outboard position's direction of rotation doesn't suit the Woodcut . I cannot see any way of reversing the cutter process of the Woodcut, so can anyone tell me how or if the Myford can be made to run in reverse.
I wouldn't get the benefit if I use the Woodcut inboard since the max diameter I can fit in there is 200mm and the bowl saver is designed for larger bits.
Perhaps I've suffered a purchase frenzy, so any advice will be appreciated.
Steve
Steve
