Segmented Turning
CHJ
31 Dec 2004
Cotswolds UK
Some useful segment guides for download on this site,could be used to mark your own index plates.
Also a novel approach to making your own drum sander. (See Downloads.)
Fascinating stuff!. thanks for the link. I wonder if he chooses not to use a PT or it's vital to have a sanded finish?
cheers,
Ike
I guess he has found a system that works for him, I note that he is talking working to 3 decimal places on dimensions for his smaller segments :shock:
More beautiful work.
Glad he's showed how to do it,might have a bash meself in a bit :roll: not.
Think he might use a sanded finish to give better adhesion :?:
Paul.J.
The reason for using a sander is because you cannot plane a ring of segment when they have been glued. A ring needs to be flat and even to match up with the next ring. If the rings were not flat the turning would be wobbly
