Chippygeoff
I have been giving some thought to what materials we can use for the things we make on the scroll saw. For me personally there is no substitute for a nice range of hardwoods in my timber rack but sadly getting hardwood that is planed both sides to the thickness needed is no easy thing to get. One local timber merchant stocks just oak in hardwood 150mm wide and 18mm thick and charges £7-40 per metre, a bit on the steep side. I am saving up for a thicknesser but until then I have to make do with what i can get.
Other materials I am considering are laminate flooring. It is the right thickness for many things and although it is just a veneer on MDF the sides can be stained to make it look like something other than MDF. There is MDF itself which I use a lot for backing boards. I also use birch plywood in various thicknesses. I was wondering about UPVC that is used for facia boards, it comes in very wide sections and for things that are white is ideal I suppose. I am not sure if this can be sprayed a different colour. I have looked at solid hardwood flooring which would be absolutely perfect for many items and is cheap enough for a pack. The only snag is that it is grooved on the bottom and these would have to be planed off. Pine can be readily bought planed in various widths and thicknesses but getting a good finish on pine is a pain in the rear. It will be interesting to see if anybody can come up with anything else on this subject.
