Scroll saw won't fit in bottle...
Niimus
23 Dec 2015
Derby, UK
For my latest project I decided to try my hand at a ship in a bottle.
Trouble is a 30", 52kg Excalibur won't fit the 500ml Sloe Gin Bottle :)
I made a jig for drilling 0.7mm holes in cocktail sticks by drilling a block of wood from the side and then cutting in with the scroll saw to provide a 'slot' for drilling the hole on my drill press.
The hull was cut with the saw then hollowed out with a wood carving gouge (finally found a use for the Flueroni :) ).
I'll add further picces as I progress...
Martin
    32.9 KB
what a great excuse for emptying a bottle of Sloe Gin!.......look forward to seeing it on its maiden voyage
Brian
You do know you can get 70ml Sloe gin don't you?
Of course it will need using up before you can pop a boat into the empty :D
That looks like a very good project Niimus. Nice precision work. More pix as it progresses please.
Like others here, it also occurred to me that it's "only" a question of emptying a bigger bottle (of gin or whatever else you fancy) to make the job a bit easier! Though I guess it would also depend on what was in the new bottle to start with.
:D
AES
