markh
Hi Guys,
Newbie here.. My Scheppach HS-2 Kombi (20 years ish old but not used much) keeps blowing 13 amp fuses. The motor is rated at 9.5 amps, but when I put a new 13amp fuse in the plug and turn the machine on, I get a low humming noise for a few seconds, then nothing. The motor does not turn. On button does nothing after this until I replace said fuse when the same thing happens again.
Any ideas? Could it be anything to do with cold & damp or does the old girl need a bit of TLC?
And another thing......... My 12 month old Record Power BS300 bandsaw will only work if I keep the on button on the NVR switch pressed all the time. As soon as I let go, it stops (ie it won't latch on).
Either I'm having a bad week or the cold is getting to both of them!!
Any help appreciated from any wiggly amp wizards out there!
Cheers,
Mark
Cheers,
Mark
