I've recently purchased a second hand Scheppach Basato 5-2, and was wondering if anyone here had experience with replacing the blade guides? The ones I have are all pretty worn - it looks like both of the thrust bearings have jammed at some point and the blade has shredded them. I've looked into getting spares, but they're pushing £200 a set, which is obscene for a wear item.
I'm looking at modifying my bandsaw to use standard 6200-2RS ball bearings, which are a much more reasonable £3 each. I've looked about a bit, but can't find an aftermarket set that will fit. I'm also struggling to find a consensus as to which part of the bearing the blade should ride on. The Carter etc mods seem to prefer using the edge of the bearing, but Matthias Wandel has some convincing arguments on using the face fo the bearing.
Has anyone done any work on this sort of thing before? Some advice would be greatly appreciated.
