Scheppach bandsaw problem
murphs14
26 Oct 2011
london
Hi everybody please can you help? I have a Sheppach Basato 3 bandsaw that won't work. When I switch it on the motor won't spin and a buzzing comes from it. The motor and the blade are freely moving so there is no jam I have removed the motor, taken it apart and cleaned it inside. There was no obvious damage but when I reassembled it, it is exactly the same. Don't know what to do now. A new prof is going to be expensive I think. Is there anything else it could be?
Peter
Hi thanks for the quick reply. Any idea where I would get a replacement capacitor?
Peter
A good source of capacitors [with knowledge] - try Power Capacitors 01 21 708 4522
cheers
Paul
Scott+Sargeant Woodworking Machinery Ltd
Hi got one the start button willl not hold in has it got a centrifugal switch in motor? To provide voltage back to the switch to energise in Frarundcwhkll you hold in the switch
