Sanding inside hollow forms
Dalboy
18 Sep 2008
Canterbury United Kingdom
Do you sand inside your hollow forms if so I thought that THIS may interest someone. You don't need to understand what he is saying as I think it speaks for itself
I try to turn mine with a hole too small for a hand so only have to sand a finger's reach inside!
S
You can buy webrax mounted domes ready made quite cheaply - Silverline brand I think.
I found some in the local tool hire shop of all places.
Thought I saw some at The Toolpost early last year.
Edit: (to save having two posts in succession)
I also use extra long locking forceps to hold abrasives where the access is too small or too deep. Stainless steel, straight or curved, cheap & readily available - try your local fishing tackle shop.
    14.6 KB
Just remember that when using forceps you should hold the outside rather than insert your fingers in the holes of the handle. If - heaven forbid - the abrasive were to catch, fingers in holes become pretzels very quickly.
