megga
Any one tried a go at one of this chaps guns????
http://www.youtube.com/watch?v=-z--omK1 ... ubs_digest
gilljc":17bchsm7 said:reckon someone should introduce this guy to stack cutting tho.....
martinka":wp5x802r said:gilljc":wp5x802r said:reckon someone should introduce this guy to stack cutting tho.....
Spotted that straight away
Thanks for that, I will try to convince my brother to make me one.megga":vws6rk50 said:Any one tried a go at one of this chaps guns????
gilljc":vws6rk50 said:Excellent! would it be wrong to make one so I can shoot my pupils in the ear when they look down at gear stick? :shock:
chippy1970":eleaduy0 said:martinka":eleaduy0 said:gilljc":eleaduy0 said:reckon someone should introduce this guy to stack cutting tho.....
Most of the parts are not identical so surely no point stack cutting ?
Sent from my HTC One using Tapatalk
martinka":1t2ovpe1 said:chippy1970":1t2ovpe1 said:martinka":1t2ovpe1 said:gilljc said:reckon someone should introduce this guy to stack cutting tho.....
Must be my eyes, I could have sworn a number of parts were doubled up for the main body of the gun.
chippy1970":2l5is079 said:Most of the parts are not identical so surely no point stack cutting ?
A couple maybe but if you look carefully some look the same but they're not exactly the same.
martinka":2q01k35s said:chippy1970":2q01k35s said:Most of the parts are not identical so surely no point stack cutting ?
Well, you had me downloading and printing the drawings out to check. I may as well make it now, except I don't have any 4mm ply![]()
I can see at least 7 pairs that can be stack cut as they are identical, plus some others where the only difference is drilled holes, which can be done after each pair is cut. For one item, four can be stacked and cut at once. That's a fair amount of cutting saved.
MMUK":2ievhz64 said:
Harbo":3ezgr8h0 said:At school we used to make darts out if a straw (from the milk allowance) and half a swan pen nib.
Very light but sharp and accurate. When the teacher went out of the classroom we used to pick on someone at the front, all aim together and fill his scalp like a pin cushion!
Rod
