Dissolve
I've been trying to shape some complex pieces on my router table using very shallow depth cuts in american maple, I've left around 0-1mm of material outside of the template and I'm attempting to take a 5-10mm deep pass at a time.
The piece is quite long and has straight sides with tight curves at either end, obviously the straight sides that run with the grain are a breeze to route as I can hold the end to the left of the piece and then glide the work into the cutter and almost "pull" the work away which feels much much safer.
But when it comes to routing the opposite side, I reach the end of the piece and guide the work past the router cutter on the end grain and exit the cut, the shallow depth leaves a decent finish on the end grain, but when I come to starting the cut again, I'm obviously then left trying to almost "push" the piece into the cut which is much more intimidating, obviously the cutter is going against the grain orientation, but the 5mm depth of cut should make light work of that, I'm just concerned about where I should put my hands when trying to attempt entering the cut like this, I know actually pushing the work into the cutter is a bad idea, in these situations, how is it best to enter the cut when you have start on the end of a long piece and work round to the straight edge?
Should you always be leaving your hands on the exit side of the router table? Should I be using a starting pin to steady the entry cut?
Grateful for all advice!
