router table plate
18 Oct 2012
Ellesmere Port
Im wanting to turn my home made work bench to have a router table in built, were can i get a cheap metal plate from or can i make 1 from an other stuff plz
You could do what I did - pick up a piece of scrap ali sheet that I found kicking about at the side of the street and make your own! It's really not that difficult - just marking from the base plate and drilling a few holes. (This was for a relatively light 1/4" router - I've no experience of big heavy 1/2" ones.)
Have you tried the 'flea-bay' Chris?
There are plenty of metal stockholders on there who sell small pieces.
I'd advise no thinner than 10mm Ally sheet for a router table insert.
Tufnol is another option but maybe 12mm is the best thickness for this stuff.
BTW. With a variable speed router you can machine Aluminium, as long as you stick to the recommendations in your manual.
HTH
I'd opt for steel rather than ali. Ali is very easy to scratch and that then marks your workpiece. It also has a high drag character. The downside is that it is more difficult to machine.
S
