Neomorph
As I'm in the process of building myself a router table I was thinking about designs of fences that I've seen. Most of them use a pair of T-Track embedded in the table and the fence is connected to these with two T-Nuts and lobe nuts. Looking at this setup it's obvious that it is virtually impossible to move the fence back in parallel.
Looking at the other end of the scale there is the Incra that attaches to the center of the fence but this looks like there could be a small amount of play at each end. Also the size of the mounting on the table means that it limits the amount of movement. that the fence can travel.
Contemplating this I tried to come up with a way to make the fence run parallel but allow full use of the depth of the table. I threw out several ideas as being to unwieldy but then I happened to glance over at a table that had some bits and pieces for another project I'm working on. There sitting in plain view was a full extension ball bearing drawer runner. :idea:
My idea is that the runners are embedded into the router table top and there is a central T-Track used to fix the fence at the desired distance. The runners will ensure the fence is kept parallel and if I can figure out how to fit an extender it could mean that I could even use the fence right up to and past the back end of the table top. This would mean it would be easier to run dados on panels.
