I have a 10mm aluminium router plate in which I need to drill and countersink 3 fixing holes, to accept M6 countersunk machine screws. Whilst I'm reasonably comfortable with the marking out (using the Router's phenolic base as a guide) I'm unsure about the best way to drill/countersink the holes and would appreciate advice.
I have a drill press and from my research so far should be using around 2,000rpm for the 6 or 6.5mm holes. I propose making a 4mm pilot hole and then, probably, a 6.5mm final hole (to allow a smidgin of wiggle room for the screw), using HSS drillbits. Does this seem right and do I need to use lubrication?
My main concern is the countersinking (90 degrees angle). Can I use my normal steel rose type countersink or is there some special countersink I should be acquiring? Is it better to countersink after both holes have been drilled or after the first hole, as this may lessen any 'wobble' of the countersink. What speed should I use - I'm thinking the slower the better (think my drill press goes down to about 300rpm).
Finally, any special considerations for larger holes e.g. the 17mm hole I need to drill for the fine adjustment access ratchet (it's a Trend T11 router), or is it just pilot hole, then gradual step up in drill sizes. The 10mm thickness precludes the use of a step drill which, otherwise, would be ideal.
P.S. a local machine shop wanted £75 to do this for me which seems steep (or am I out of touch with prices :? )
