chr15athome
Hi All,
I am new here.
I am currently looking to make custom MDF skirting boards for a small project I have coming up.
I am using 18mm MDF 2440mm x 1220mm cut into 4ft and 5ft 180mm strips.
I will have an mdf template to folllow for the shape.
I have some questions about the next steps:-
1. Once the wood is cut up I planned on rough cutting the shape out with a jigsaw about 2mm clear of the shape. But I had hoped there might be a quicker alternative that I could use some kind of rough cut router bit with my template. I did see some drill bit style rough cutters but not sure if they are available in the uk.
2. I would then just use a straight router bit to take off the excess, all the straight bits I have don't have a guide bearing at the bottom so presumably I would have the guide template at the top of the work piece and some sort of guide collet? Can i do this in 1 pass?
3. Once the work piece has a nice smooth straight edge I plan on using an Ogee Classic router bit to cove and round the edge. Which is pretty straight forward as it has a guide bearing/bush below the cutter so it would just run along the edge of the work piece.
Any help or opinions regarding this process will be greatly received.
Many thanks
Chris
I am new here.
Many thanks
Chris
