Alexam
Bandsaw Boxmaker
I saw this video recently and wondered if anyone here has made one of these for their router table?
https://www.youtube.com/watch?v=lIzyEHZz3z0&t=195s
Malcolm
Malcolm
siggy_7":lbdu41e0 said:Yep. I built mine after seeing the Incra CleanSweep system. My setup consists of a custom router plate with a 110mm diameter recess 3mm deep, and a 90mm diameter hole through the insert plate to accommodate a large panel raiser if I ever want to use one. I've made my own insert rings out of 3mm perspex with circumferential slots routed into them basically like the Incra inserts. Beneath the table I've got an MDF box that encloses the router, hooked up to a 100mm extraction port. The door is a simple hinged affair with some foam weather strip to seal it. I have a port in the box to connect my router fence extraction hose to the cabinet, so I have simultaneous extraction above and below the table from one extractor. Used with a twin motor extractor (Record DX4000) I get practically no waste uncaptured. The difference when I forget to shut the door on the collection cabinet is very pronounced!
