Bod":2esz6w8i said:Genius!!!
You only work on the rebates carefully, then only perhaps one corner.
Then just hog off, to the rebate depths.
They knew a thing or two these old old boys!
Bod
You get essentially the same effect by using four small pieces of 6 mm ply, or anything else that will raise the sticks (two for each winding stick) laid on the two edges of the board prior to resting the winding sticks on them. Not fancy, but works pretty well in my experience. My comment is not intended to knock the modified winding sticks illustrated, but it is another way of doing the same job. Slainte.Fromey":wwcwlzef said:
Sgian Dubh":apn6x4ou said:You get essentially the same effect by using four small pieces of 6 mm ply, or anything else that will raise the sticks (two for each winding stick) laid on the two edges of the board prior to resting the winding sticks on them.
In this instance I say 'whatever floats your boat' is good enough. I'm trying to recall when winding sticks of any sort where critical to me in the successful production of a wooden artefact. With surface planers and thicknessers to hand winding sticks are a near redundant 'ornament' for the most part, although I used them quite a bit in the 60s and 70s (and even some in the 80s) when I squared wood quite frequently with hand tools. Slainte.bugbear":rmnhu2ic said:Given a choice between arranging four little scraps, or using a rather lovely tool, I'd choose the latter. But then, I freely admit to liking "rather lovely tools". BugBear
Sgian Dubh":2uw7gnr5 said:With surface planers and thicknessers to hand ...
bugbear":1gln498s said:Sgian Dubh":1gln498s said:With surface planers and thicknessers to hand ...
This happy condition does not pertain to my workshop
BugBear
DTR":1oxpw275 said:bugbear":1oxpw275 said:Sgian Dubh":1oxpw275 said:With surface planers and thicknessers to hand ...
BugBear
Nor mine
