Not completely inoperable, just the piezo-electric ignition. But here's the problem -when I try the torch out, detached from the gas bottle and minus the burner, I can see a spark. It's a bit of a conundrum - much along the lines of - does the light go off inside the fridge when you close the door. I can hardly stick my eye over the nozzle to check everything is working , when it's all connected.
And, for those of you with a logical, methodical frame of mind, The gas is flowing, and it does smell of gas. The only thing I can think of, is that, the spark is not hot enough, and therefore the piezo-electric ignition is at fault. I note that there is a service kit available, for about 30 quid, though no one seems to be listing exactly what the bits and pieces in the kit are. So does anyone out there have experience of this problem, and is replacing the ignition the likely solution?
