Rotating and aligning objects - arghh!!
gidon
19 Mar 2003
West Dartmoor, Devon, UK
I've got in a right pickle - I've created some objects which I'm trying to place correctly. But basically I'm making a right mess of it. See the pic below - I just want to join the two parts of the lever cap together and place that on top of the blade? What's the trick?
Thanks!
Gidon
Gidon, I would use some construction lines to help orient the lever cap parallel to the plane body. Then use the Rotate and Move tools as needed. If you send me the file I can draw the lines and make some screenshots for you.
Many thanks Dave - will do. I have sort of tried that - I move the bottom left of the lever cap to a line but I can't rotate in the right direction the other side to bring it right!
Gidon
Dave,
Looks like you've got the topic for this week's Friday Tips. :wink:
