Rockler Thin Rip Jig
Just type in "Single Point Fence" into Google and you should come up with a few different versions, including several instances of DIY versions.
If you want to use one as your Rockler example in combination with a fixed fence then the blade tracking must be perfect.
Most folks use Single Point without the fixed fence or a just a featherboard, it can then be set to compensate for Blade drift.
I've managed to knock one up from materials to hand but not had reason to try it out yet. Main part is made from a 16mm Phenolic off-cut from a bench top and I've fitted a 14mm bearing into the end.
