This is an excellent tool, but often found minus its Stanley blade.
As a 112 owner and user myself, you have a number of options:
1 - Find a Stanley original in good order. Great for authenticity, but hard to get and potentially expensive.
2 - Find a replacement: They are still made. Kunz make an identical version of the 112, and the blade is interchangeable. Not sure if Ray Iles makes them , but, Dieter Schmid in Germany sell the Ron Hock version. Factor in the Euro conversion rate, any penalties in Euro-conversion on your plastic (read the small print, some do some don't) and delivery costs.
http://www.fine-tools.com/eisen.html
The German suppliers are very good to deal with and deliver quickly. According to their information, the Hock blade comes in at 3/32" thick; I think that the original Stanley was 1/16".
3 - Use another type of blade: The Veritas version has a 1/16" thick blade that will fit quite well, even if it is a bit shorter and doesn't give much play for sharpening over time. The Lie-Nielsen equivalent blade is too thick at over 1/8" and will not fit in the throat.
4 - Fit an ordinary hand scraper blade: They do work, if a bit on the flimsy side due to their inherent thinness, but you have to use them end-on......... or cut up an old saw blade.
Finally the dimensions that you need are: 2 3/4" wide x 1/16" thick and around 4 1/2" to 5" in length. Taken from my own Kunz blade that burnishes and works quite well, despite the image they have of poor quality.
Hope that this helps.
