caitrionahoran
- Joined
- 19 Jan 2023
- Messages
- 31
- Reaction score
- 7
I'm re-doing a small shower room in a timber framed building. It is fully tiled with small tiles on plasterboard over the stud walls. The shower enclosure is slightly too small for a 700mm tray and is currently just floor tiled square area under 700mm. My idea is to remove both tiles and plasterboard on all walls and use thinner waterproof sheet material. I'm hoping to be able to either fit a tray 700x 100 extending out into the room or maybe create a wetroom. Have removed tiles in a small area 4ft x 4ft and found as the plasterboard was coming away anyhow using a chisel, the quickest way was to just hammer the tiles and plasterboard with the mallet. I also want to replumb with plastic pipe and am considering running this in the wall. Any tips on any aspect of this would be welcome. Thanks
