Removing 3-in-1 oil from unfinished elm
RogerS
20 Feb 2004
In the eternally wet North
I was oiling the hinges on one of our doors and to my surprise and vexation the hinge ejected some of the oil as I worked the door back and forth. It eneded up over a small elm (unfinished) door that hides the mains stopcock.
'Oh bother' said I. Or words to that effect as I filled up the swear box.
Options?
Start again?
Wait a while so the oil dries and then maybe try blotting paper and a hot iron to draw out most of it? or would the iron drive the oil in further.?
Wait a while until the oil dries and then scrape and sand and hope it hasn't gone in too deep ?
None of the above will work though it will fade a bit as it dries.
If it still shows just oil the rest of it to match - raw linseed half n half with turps brushed on thin and wiped off.
Fullers Earth will remove the oil but the timber has to be horizontal as you will need to pile a 1/4" of it over the stain and leave it for several days to absorb all the oil. On one heavily oil soaked piece I worked on it took three weeks to take all of the oil out but it left a clean and dry surface in the end, you just have to be patient with it.
Brilliant idea, thanks, Paul. Any idea where I can it locally or is eBay the best bet?
I would try nail varnish remover (acetone) ..gently. I also wouldn't leave the 3-1 too long lest it dry off. Best wishes.
You can get it from Amazon, £5.00 for half a kilo. I always keep a jar of it under the kitchen sink, it also is really good at taking out oil stains from clothing and on one occasion a pair of suede shoes.
Thanks, Paul. Will try it out.
