For your amusement, here are my ramblings about the Maxi. Just my
personal opinion, obviously:
> > "To be fair, I haven't ever used it as a spindle moulder so I can't
> > comment on that. However, it is my only planer/thicknesser, so I
> > *have* to use that (and the T/S when I must).
> > My main gripes are:
> > The manual stinks.
> > The fence flexes and doesn't stay square, and there are no instructions
> > on how to adjust it. I've been reduced to shoving shims under it and
> > clamping a block of wood at the other end to keep it still.
> > The adjustment for the tables is finicky and almost impossible to
> > get at.
> > The manual stinks.
> > The outfeed table drops of it's own accord because there's no positive
> > stop to prevent it (just bolts in slots)
> > The infeed table height adjustment is extremely hit or miss, and the
> > clamping knob to hold it firm doesn't work.
> > The given depth of cut possible is overly optimistic. Anything more than
> > one millimeter and the motor stalls.
> > The thicknessing scale was 3mm out, until I replaced it.
> > Did I mention that the manual stinks? ;~)
> > The saw blade tilt is adjusted with a lever which gives practically no
> > control over the angle.
> > Every time you remove the crosscut fence you have to reset it square
> > to the blade. But it always slips into the (incorrectly) placed "90 deg"
> > stop, so I've never yet got it square. That's why I hardly ever
> > use the T/S.
> > The tablesaw insert has to be bent to insert it in the table. It then
> > *stays* bent and never lies flat again.
> > I think that'll be enough to be going on with ;~) Certain aspects of
> > the Maxi may have changed (ours is about 5 yrs old, now) but I really
> > doubt that it'll be enough to make any difference. Really, save
> > yourself before it's too late and get something -anything- else."
