hi again, i posted in july regarding supernova chuck and was very grateful for input. i have now purchased a supernova 2 and i'm pleased with it but cant compare because its my first. my new question is........does anyone have or have used a record DML36SH-MKII Swivel Head Lathe ????
my problem is, when i am trying to hollow out, the rest doesnt seem to go low enough. the gouge (with the rest at its lowest ) seems to be at best, bang on the centre or at worst slightly above centre depending on which gouge i use. i have ground down the rest body ( not the part the tool rests on ) to try get it lower but i am restricted as the releasing mechanism seems to dictate how low the rest can go. my next move i think would be starting from scratch and welding a new, custom made rest for this lathe. am i doing anything wrong or does this lathe have a design fault. i get the feeling this lathe is purely for spindle turning as i also had a go at turning a bowl and found the position needed to stand comfortably would suit a three handed person with a permanent left twist to the spine.
i paid for a one to one lathe instruction where the chap used a jet JWL1220VS VARIABLE SPEED mini lathe. totally blown away with this lathe. any advice on the mini lathes. is this the best or is the ; SIP 01936 , Charnwood W815 ,
DRAPER WTL330 (or one anyone else knows about) better or as good as ?
thank you
john
thank you
john
