Proper way to do a kitchen cabinet corner?
Doug71
28 Aug 2016
Yorkshire
I'm fitting a kitchen and have a few corners like this to deal with
They have sent some slab doors to cut down for the corners, I know there are a few ways of doing them but I just wondered if there is a "proper" way?
I want the doors and corners to be inline so the corners will need to stand forwards about 3mm from the carcass (same thickness as a door buffer).
I was thinking of putting a fillet across the corner then making up a 90 degree piece from the door slabs with some buffers on the back to space it off but not sure about the gap it leaves behind it? Something like this
I can think of other ways of doing it without leaving a gap but as said I wondered if there was a proper way?
Thanks, Doug
Doesn’t look anything wrong with your sketch Doug, I’ve certainly done it like that on numerous occasions when there isn’t a preformed corner post.
seems good to me as well, don't do lay on often but our fitters sometimes use this method and I've never complained :)
Yes it’s like that in the shop-bought, self-assembly ones I’ve done, but the corner piece is fatter, which includes the size of your spacers. But maybe you knew that...
Your plan looks pretty good.
I will just add that if you use something like buttonfix or another removable cleat method it can be handy as it can be removed non distructively.
Ollie
