pidgeonpost
After years of making do with a bench cobbled together out of scrap 3 x 2, 4 x 2, floorboard, and chipboard I've recently acquired a Sjobergs bench that has a 'proper' woodworkers vices (two). Each vice has a wooden jaw, the usual heavy central screw, and two plain steel bars running parallel to the screw - I'm sure you know the sort.
The vice grips well on any timber that will sit horizontally above the screw and bars, but anything wider than about 4" is too wide to drop between the bar and screw, and has to be located at one end of the vice (typically if you're taking a shaving off end grain where the timber is too wide for your shooting board). The grip here is poor as the jaws pull out of parallel if you apply anything like a reasonable amount of grunt, and the timber moves in the jaws. OK, you can always drop a piece of timber the same size into the opposite end of the jaws, which has the desired effect, but you then need three hands or a dexterous leg to hold two pieces of timber while you tighten the jaws. I can't be the first bloke to encounter this 'feature'. Anyone else suffering from this, and any other tips to overcome it?
p.s. I still have my old Record woodworking vice, but would prefer not to have to fit it if I can avoid it.
