woodman-46
- Joined
- 22 Aug 2004
- Messages
- 27
- Reaction score
- 0
Hi,
I have recently taken delivery of a Tormek 2600 which I shall be using to sharpen , among other things, thicknesser/ jointer blades and Morso guillotine blades. I have made my first attempts on the guillotine blades and have followed the instructions implicitaly. The problem I have come across is with the angle setter. This is the bolt at the back of the jointer jig which comes up against a block to determine the angle.
I have placed the blade up against the grinding wheel and set this angle using this bolt and block. Once done I have set the depth of cut and pressed down as instructed. The picture in the book and insructions shows a gap appearing between the blade holder and the "track" that will disappear as the grinding is completed. What is happening though is that instead of this gap staying open the bolt and block at the back are being pushed apart resulting in an inaccurate angle. It doesn't seem to matter how hard or soft one pushes or where one holds the blade holder when one moves it from side to side the angle setter opens instead of the gap between blade holder and track. Has anyone had this problem and any suggestions.
james
james
