Problem with sawdust paste
brianhabby
24 Sep 2006
Colwyn Bay, North Wales
Hi there
I've read several times that you can mix sawdust with some PVA glue to make a paste to use as a filler in open joints etc.
I tried this but the stuff had dried very dark and really shows up on the wood. Is this normal? and if not, what might I be doing wrong?
I would have thought it should dry the same colour as the wood since the PVA dries clear :?
I'm using it on oak if that matters.
regards
Brian
Hi Smudger
The PVA I've used is from the same bottle that I used to glue up the project and there is no indication of darkening anywhere else.
regards
brian
