My friend has a Lexmark P706 (USB Inkjet) printer, which was fine until recently. Now, it will not print at all - not even a test page - and the power switch flashes (flash, flash-flash, repeat). This occurs even if the USB cable is not connected (indicating a printer-borne fault rather than a software fault, IMO). Sending a print request to the printer when it is switched off brings it on-line, but it immediately reverts to the condition described and a "Not Connected" or "Cartridge Problem" error box appears, neither of which is correct.
I've installed the latest driver, uninstalled and re-installed, replaced the USB cable (to eliminate it), removed and re-fitted the cartridges, all to no avail. The manual says that the flashing power switch light indicates "The print cartridge carrier is stalled."
Anyone got this printer / experienced this problem / know of a solution?
TIA!
Ray.
TIA!
Ray.
