Alex H
Moved to a new build house about 15 months ago. kitted it out with lamps, towels rails etc and some not very cheap toilet roll holders from one of the big sheds.
Now the problem has appeared and I can't see any way to fix it. Your help is appreciated.
The bar that holds the roll has a square end to fit in a square hole in the mounting plate.
It's held in place with a screw.
The mounting plate is then screwed to another plate on the wall.
Over time the bar has dropped so it's no longer horizontal.
This is due to the square end, not being square (for whatever reason) as in the picture - and the screw can't hold it no matter how much I try and tighten it.
I have 4 of these and I'd rather not replace them.
I don't think filing the square down further will work, as it will shorten the bar, making the gap between bar and wall smaller.
Any ideas?
Any ideas?
