I was intrigued by the idea of using a batten with a birdsmouth notch to hold a piece against a single dog for planing after seeing a video demo (edit: found this again, it's at http://www.theenglishwoodworker.com/?p=1434) . It looked really effective at holding the stock for diagonal planing, yet the stock can be lifted and flipped over very quickly.
An essential for using the birdsmouth batten is some sort of holdfast to clamp it down to the bench.
The large solid metal holdfasts which you fix with a hammer are too pricey for me as is the Veritas Bench holddown with the screw tightening. The Axminster bench holddown is more reasonably priced but requires a collar to be inset into the bench.
Also all of the above have long stems which stick down below the bench when holding thin stock, I don’t really want to lose my underbench shelving.
I found some designs using an F clamp with the head removed and a swivel added to the end of the bar. Unfortunately any F clamps I have with a decent sized throat are much too big to go through my ¾ dog holes.
Then I found the Sjoberg QSh holdfast, it doesn’t protrude below the bench and looks a bit like an F clamp with the head removed and a kink in the stem to wedge it in the bench.
First attempt to make something similar saw me drill out the pin on a large F clamp to remove the head, then drill out another hole further up the shaft offset enough to give me a kink something like the catalogue holdfasts.
I used a bit of 12mm threaded rod inside a ¾ dowel for my first attempt, it bent like cheese as I started to tighten. Then I tried a bit of 12mm square steel with wooden facings cut from a dowel. Worked sort-of but was still starting to bend in use. Interestingly neither of them tried to rise out of the dog hole, the kink seemed to wedge them firmly in place.
Then I found an old ¾ UNF bolt I’d bought some time ago when I first got a lathe. My idea then was to shape the bolt to make a ¾ 16tpi tap to thread wooden faceplates. I never used the bolt, sticking a 3/4 UNF nut to a plywood circle proved a lot easier.
After knocking down the threads a bit the bolt is a good fit in my ¾ dog holes, it locks down the work solidly, total cost very little.
Regards
Jim
Regards
Jim
