Polycarbonate or acrylic sheet
user 19915
25 Jun 2014
How would you cut Polycarbonate or acrylic sheet jig saw ?? any suggestions
Mock
Depends what type of cut you need. But to be honest, I'd cut it exactly the same as I'd cut wood - mitre for cross, tablesaw for rip and jig saw / bandsaw for curved.
The trick seems go be getting a good feed speed.
My bike has a 1/4" thick screen, and I'm not tall, so I decided to take about 2" off the top. I marked it and got out a new jigsaw blade. Concentrating on the curve (and it's not flat either) I didn't go fast enough and, to my chagrin, the cut closed up behind the blade, as I was scuffing and melting rather than cutting it. I also think the blade was too fine - the woody rule about three teeth in the cut doesn't seem to apply.
Since then, I've had excellent results on bandsaw, tablesaw and even mitre saw, but in each case being sure to go fast enough and to arrange really good chip clearance. On the mitre saw the stuff gets everywhere, as it's fluffy, not at all dense and statically charged by the cutting process.
All done for now i use the table saw the only problem was the Polycarbonate sheet kept rising on the blade so thank.s for the advice
Mock
