Mezzanine Rob
Hi All
Started to dimension some cherry this weekend, now I have never used cherry before so please excuse me if I am being dim.
My P/T is the Axminster PT106 and has previously dealt with everything I have thrown at it, mainly beech and oak plus some soft woods. I surface planed the two boards without too much trouble taking very thin and slowly fed cuts. When I came to thickness the boards they stalled the machine on only 0.5mm cut. So initially I cleaned and re-waxed the table then sharpened the blades until all looked satisfactory. The improvements were only marginal I could only machine the cherry with the thinnest of skimming cuts taking an absolute age, still stalling the machine twice in the process.
Is cherry exceptionally hard and reknoundly difficult to machine or do I have a problem I need to talk to Axi about?
I have had the side off the machine and the drive "V" belts look if they could be a little tighter but I can't find the manual ( Although probably useless if I could find).
Does any one have this machine and suffered similar problems?
Hopefully your replies can put my mind at rest, as I can ilafford a repair bill or worse at the moment.
Regards
Rob
Regards
Rob
