YorkshireMartin
Hi all,
I've just taken delivery of an Axminster AW106PT2. It's a 240v model with a 13 amp fuse.
After commissioning the machine I tried to test it. Unfortunately, all I got was a buzzing noise until I pressed the emergency stop. Attempted several times.
I've contacted Axminster tonight so should hear from them tomorrow, but I thought I'd ask here to see if there might be something I've overlooked as I'm far from experienced in this regard.
I've read that in some cases a 16 amp socket can be necessary for these machines. The supply to the garage is standard 13 amp and from what I could see, appears to feed from the Wylex consumer unit which I think has a 20 amp fuse in it. I'm guessing its 20 amp as the cooker circuit is marked B32, which I'm guessing is 32amp and the feed to the garage is marked B20. My electrical experience is virtually non-existent beyond fitting a socket or a light.
The strange thing here is, if it was attempting to draw too much power, I'd expect it to trip the fuse on the garage circuit, which isn't happening. Literally I get a buzzing noise from the motor and nothing else. The lights dim ever so slightly for a fraction of a second when i turn the machine on, too.
As far as I can tell, the machine isn't jammed, although the noise its making would be what I'd expect if it was. I've inspected it carefully and I can hand rotate the blade carrier with some effort, the chains also rotate freely as does the band. Lubrication was applied as per the manual, I used machine oil.
Does this sound like an electrical issue, if so, can I fit a 16 amp socket on a 20 amp circuit? Just sounds a little too close to capacity to me, but I don't know. Already on the circuit I have a freezer and 6 strip lights, plus a dustbuster on charge and a clock/radio. I did try to start the machine with the lights off, which made no difference.
I'm sure Axminster will sort me out one way or another, but I just thought I'd see what you fine folks thought of the situation.
Any ideas?
Many thanks,
Martin
Any ideas?
Many thanks,
Martin
