planer stuff for 9fingers
kostello
11 Feb 2011
slightly more sunny flackwell heath
so i've got some pictures of the gauge............
basically the central part of the gauge sits on top of the blade so it sits at the correct height from the block.....the blade sits up about 1.5mm from the cutter block
hope this helps
    29.6 KB
    22.2 KB
    88.3 KB
Excellent! Thank you very much indeed Sasha.
So the black bar simply joins the two jig ends together - now I understand
To anyone wondering about the background to this.....
Sasha is selling a very similar planer to mine here for-sale-12-1-2-thicknesser-t56392.html and showed a picture of a setting gauge. I don't have one of these gauges and asked for some further details so I could make a copy.
Bob :ho2
My Jet thicknesser came without its setting gauge, and the pic in the instructions looked exactly like that one, although with only one contact. I made up a gauge out of MDF, which I figured would be kinder to the blade, and probably last for a reasonable time. So far, so good.
I've always understood that planer knives should be set referenced to the out-feed table. So, unless the planer block is known to be precisely level with the out-feed table, how can the gauge be accurate?
Bob:
Here are some do-it-yourself gauges that use a dial indicator. I get the knives on my 18" thicknesser to within .001" with the cutter head gauge, while I set the head, feed rollers, and chip breaker with the three-footed one. Full article is here:
http://wiki.vintagemachinery.org/Gettin ... mance.ashx
Videos are here:
http://wiki.vintagemachinery.org/Jointe ... ideos.ashx
Roger: You are correct. To that, however, you align the tables and head (not knives) first. After you do that, you can set the knives to the head.
Kirk
