A method I have used with some success is to rip a couple of cuts in a 4x2 at 45degrees in a Vee (90 degrees included angle) and because the kerf of the blade I use is fortuitously the same as the thickness of my Sheppach blades, they are a push fit into the rip cuts.
I then put the wood with the blades in it, on the drill press and use a cup-type grindstone to skim the blades. To avoid the 4x2 shifting about, clamp a couple of fences either side.
A light honing with a diamond stone is used after this operation. Because the two blades act as a support for the stone, there is no difficulty in maintaining the proper angle with the hand held diamond stone.
I found the 45 degree setting worked OK but I think the original angle on my blades was probably more like 40 degrees. To rip this on my table saw, I would need to shim up one side of the 4x2 for the cut.
I used this method a few times before I dropped the stone and broke it, then got a jig for the Tormek so that is what I use. Results are about the same.
