Pine bathroom door finish advice
dave_87
3 Jul 2013
Basildon, Essex
Hello,
I've recently hung a new bathroom door, it is solid pine and so far just given it a coat of coloron Danish oil.
It's at the colour I want so don't want to add extra coats as it may darken it.
Should I give the inside a coat of something else to protect against moisture and if so what would be advised?
Thanks,
Dave.
Sent from my HTC One_M8 using Tapatalk
I think this is one of those things where a lot depends on the actual door and the wood in it whether adding more finish will make any difference. I'd be tempted to varnish myself but it might be fine just as it is.
If you do want to varnish I'd thin it and wipe it on for ease of application, makes it a doddle to get a good surface.
