Piano hinges
LeeElms
22 Apr 2004
Bracknell, Berkshire, UK
I need a small piano hinge - width of each leaf 9mm or less, and as thin as possible. Length about 90cm.
Can someone suggest a supplier for a single hinge of this type that is reasonably priced ?
Thanks ...
It's used by those people who make small boxes, like jewellery boxes and the like, perhaps a craft shop might stock em, or one of our members might sell you a piece that length if you ask...bosshogg :)
I never teach my pupils. I only attempt to provide the conditions in which they can learn.
Albert Einstein 8)
I have two types of piano hinge stainless undrilled so you could cut the flaps to whatever size you need or solid brass already drilled but you could reduce to 9mm and redril holes... But 90cm isn't a small hinge ?
